Andrews 48 and TTS
Crazy, did you get the machine running OK? I just installed my 48H's this weekend and used the file number CYA176-03 as a start point (A/C, Yuill Elite D Pipes & cams). I am thinking about using the CAA176-03 (A/C, exhaust, 255 cam) file to run the bike.
Did you look into the program a bit where it allows to to adjust the came intake lobe open and close? I found that today and worked on the file a bit, but didn't upload it into the bike yet.
I'd love to hear what you did if you got it running, I am still working on mine.
The 255 map for whatever model bike you have is a good start but not perfect. This summer when I get home I plan on doing several anti knock test runs and, if necessary, adjust the spark timing then do some v-tune runs. A full dyno would be better but I don't have one anywhere close to where I live.
msr082881
02-20-2015 04:28 PM
