Accessory power outlet?
I just found what looks like an accessory power outlet just in front of the battery box. It has a red wire leading back into the loom that goes to the fuse box, and it's essentially zip-tied to a crossways frame member in front of the battery box. Looks like the female side, so that an appropriate male electrical connection could just slip in, with a ground to some nearby screw.
Am I interpreting this correctly? Don't see anything about this in the service manual. This would be a great place to find power for my new tach, if so! |
RE: Accessory power outlet?
That is your HOT Accessory line......
Always hot, not grounded.... If you look at your ELECTRICAL MANUAL, you will see it in the schematics..... |
Thanks Shovel. So would that be appropriate to use with my tach? Is it fused? I can use that for power, ground to a screw to the frame, yes?
Oh, I think I found it. It's not switched? That's no good...
It's for a battery charger-maintainer.
What are you talking about? |
Ya that is the wire that makes my road Zepplin AirSeatwork.
Road Zepplin plugs into the SWITCHED ACCESSORY CIRCUIT (4 pin plug).......
The Red wire with the Grey connector is a NON-Switched HOT....... |
I glad i went out and looked yep 4 prong and was going to take a pic.But it,s only 2 wires the other prongs are dead on my Acc going to the switch,My though just as well to be a 2 prong.I shure like the plugs there like caterpiller equiptment. i have the seat off because I installing a in line plug for a Isolator for my time out trailer. Dam I though I had you ha ha.
[IMG]local://upfiles/3159/D11B2E5E8BD445A9BB9B8866A6387E8B.jpg[/IMG] |
The 4 wires are ....
Black - Ground Orange - Switched power Red w/ Yellow - Brake Light Circuit Orange w/ Red - Running Light Circuit... Switched (I think).... Memory is the 2d thing to go.... |
© 2024 MH Sub I, LLC dba Internet Brands
