PCIII Map 06 FLSTI - Heritage
First time posting here and I certainly appreciate everyone's advice and help. I am wondering if anyone has a map for this set up -
2006 Heritage Softail FLSTI
Stock ECM
K&N RK-3909
VH Straightshots HS
No baffles
PCIII
There are no maps for the HS version since they are relatively new. I will eventually have the bike professionally tuned, but I want to get all this stuff on and ride for a while prior to that.
I have heard a lot about Fuelmoto. Any experience with them and his pre-loaded maps?
Any help is greatly appreciated.
Stock ECM
K&N RK-3909
VH Straightshots HS
No baffles
PCIII
RE: PCIII Map 06 FLSTI - Heritage
I've heard nothing but good about Jamie and Fuelmoto...but I got my PCIII from another vendorI downloaded a canned map myself from the CD that came with the PCIII and have had good luck with it so far...Fuelmoto will ship you a PCIII with a pre-loaded map for your bike's setup that should work well until you can get a dyno tune...and welcome to the forum!
Thank you and glad to be here. My major issue is finding a map for those pipes. I can't find them in any maps and both VH and PC have not been very helpful. I know I can try to find similar pipes to map by, but I cannot even find VH pipe charactertics/specifications to compare.
Thanks again.
Thanks again.
AdrianVall
07-17-2008 09:03 AM
