dtc code po372
my 05 fatboy with carb is sick, and i am getting dtc code po372. does anyone know what this code means. i have found code po373 as a bad ckp sensor but cant find a description for po372. thanks for anyhelp
RE: dtc code po372
Hi Tex,
code seems to indicate CKP sensor intermittent. Sounds like a replacement may be required or there could be a loose/ faultyconnection. cheers Mick |
RE: dtc code po372
replaced sensor last night and bike still runs the same. what the h$%^ is going on
RE: dtc code po372
tex,
check to see if there is a wiring issue- the wiring is run pretty tight and might have worn through in some places. THis happened on an 07 night train recently and the dealership spent a fair bit of time trying to locate it. THe wiggle test comes to mind. cheers Mick |
© 2024 MH Sub I, LLC dba Internet Brands
