Thundermax ECM Thread
#151
Tmax install question
I just received my Tmax for my 2007 EGC. The oxygen sensors and throttle body are stock. A/C is SE set up and thunder max 2 into 1 with ghost pipe. I have no idea if anything inside of the motor was upgraded, so here is my question: should I wait to install the kit untill my local indy checks the cam tensioner's or just install and ride.
#152
#154
Tmax installed - suggestion
Installed the tmax last night, found the map and ran the bike for awhile. Two things I will mention as suggested by a previous member.
1) put the battery on a charger while doing this install cause with the switches on, it sure drains the battery where it wont start.
2) Put a box fan close by and turn it on, it wont take long for the head temp to get to 230 and up to 300.
Now if it would quit raining I can take it out for some riding.
#155
I agree with the folks who say that to get every last hp or bit of torque out of your bike a "good" dyno tune is the way to go. Having said that my bike runs so good that I have never felt the need to dish out $300 to $500 for a trip to the dyno. Also never forget that any dyno tune is only as good the tuner performing it. A good tuner can make your bike run like a top (do tops really run good?), but a bad tuner or one in a hurry will just be a waste of your money.
I did spend $10 for hp run on a dyno once though. 94 hp and 106 tq do me just fine.
#156
Another great idea is that if you live somewhere where there is a riding season always, always read a copy of your current tune before you put the bike up for winter.
Also if you calibrate your speedo without a pc every time you disconnect the battery you will lose your cal. Doing it on you PC within the program works forever.
#158
#160
If you planing running the bike on the on the side stand for any period of time a fan is good but I'm not sure why you need to do it with a Tmax.. Doing a side stand run or IAC calibration, you simply run up to the ending temp and shut the motor off. Adding a fan simply makes the process take longer.. If you are trying to trouble shoot some issue by running the motor, use a fan.
