Ironhead A place to talk about Ironheads.
question on shocks
Old 10-20-2014, 06:01 AM
hell hound's Avatar
hell hound
hell hound is offline
Default question on shocks
i found a good deal online for a set of burley 10.5" shocks. the describtion says fit 84 to present touring bike. Can i use these on my 80 ironhead. right now i have longer shocks with homemade lowering brackets and if i measure between the stock mounting brackets it is 10.5. Is there something that i dont realize that would make these not work
Old 10-20-2014, 07:10 AM
IronMick's Avatar
IronMick
IronMick is offline
I went to this link, put in 1980 Harley Davidson, and it did not list Sportster ...
http://www.burlybrand.com/product/27/slammer-shocks
Lots of info when i Googled burley 10.5" shocks
1979-1981 Sportsters have a different frame from all previous and subsequent Sportster years.
I do not know what is the length of stock shocks for 1980. It would be useful to know. 10.5" seems very short to me.
Anyway, hope these few comments help a little.
Old 10-21-2014, 06:55 AM
hell hound's Avatar
hell hound
the shocks that are on it right now are 12'', but it has some lowering brackets that move the bottom of the shock toward the rear. With the 12" shocks and the lowering bracket in place, if you measure between the stock mounting brackets it is 10.5" right now, so i feel fine about the lenght, i just dont know if they will fit on the bike because on this bike the shocks are so close to the rotor and sprocket
on another subject,
Mick I printed out the ironhead electrical diagnostic pages you posted a link to and i keep it with all my manuals because the procedures are better than the manual
Old 10-21-2014, 08:33 AM
83XLX's Avatar
83XLX
83XLX is offline
Just guessing, but the lower part of those shocks looks small enough to clear ok. I do know that Progressive 412 shocks have an offset lower mounting eye to push the shock outward a bit for clearance, but they are larger diameter than the stock shocks. Short shocks made for a touring bike are likely to have really stiff springs, though, and even if they fit your bike, they may not work too well on a lighter bike like a Sportster.
Old 10-31-2014, 01:46 AM
sepixlh's Avatar
sepixlh
sepixlh is offline
12.5" is OEM lenght in -80 ironhead. It's got to use shocks that are meant light bike as sportster is, BT shocks are usually too stiff ( if you are riding lone). PS 412 set has shims-set to be correctly installed. They might be some tweeking if you have saddlebags. I have god experience from PS shocks...
Old 11-01-2014, 08:07 AM
hell hound's Avatar
hell hound
i ordered the shocks, they were cheap enough to give it a try. if they dont work i think i could find someone that would want them
bigpappa160
Air Suspensions
08-14-2018 05:49 PM
notrhogrider
07-02-2015 09:07 AM
calabera
12-03-2013 06:30 PM
vintagebikes
07-11-2013 11:24 AM
brettnbama
11-22-2008 07:42 PM
Quick Reply: question on shocks
