M8 problems
#511
I would say about the only other things would be scavenge side oil pump or possibly the O ring behind the oil pump.. There still seems to be one just like on the TCs.
#512
Yuup!! 700 miles in 3 days and all I can complain about is the windburn.
And my highway pegs still need to be dialed in on the right side, left is good.
Exhaust is way too quiet. Almost got run over by a texting teen. Nothin some Big Louie's won't fix.
Clutch lever is a bit stiff but nothing compared to the old non-hydraulic clutches. It is also set out to the outter edge, not in the middle where I prefer but I'm sure that is there to avoid wear in adjustment. I'll probably adjust mine since I don't have to pay $100 an hour do do it. This I don't understand. Everything else on the bike is set up for the vertically challenged.
Lack of a tour pack relocator option is a big issue. I had to call up George Anderson. $225 out of pocket to find out if it will fit on a '17. Those who have dealt with George in the past know he won't take my money till I get it on the bike. We'll find out in a few days. Again, not enough leg room or gut room for us biguns.
Shift linkage levers are set up for dirt riders. Adjusted mine. Might need another little tweak or two.
Break pedal is too high. I suppose it is to support short riders. (I wasn't in the survey.) I'll adjust that this weekend when I do my 1000 mile.
Windshield is 3" too short. Will have to upgrade with aftermarket.
Handle bars are 2" too low.
So my only complaint is whoever was in charge of decisions was short and had some kind of vendetta against big & tall people. I'll update after my 1000 maintenance this weekend if I find anything else.
#513
Ultra Limited,
Windshield is 3" too low
First thing I changed was the windscreen to get the air off my face and I am only 5'11". Average is probably around 5'8". Good luck, ride safe.
#514
WmRickert (05-04-2017)
#515
#516
#517
Well, I'm at 6000 miles now and I think it's eating oil somewhere. I did the 5K service at 5022 miles. I put exactly 4.2 qts in and the dipstick was reading right at 8/10s full when hot on jiffy stand.
After today's ride its reading just a hair below 6/10s full when hot on jiffy stand.
I added 7 ozs and it brought it back up to 8/10s.
I'm using Mobil 1 vtwin 20w50. There are no leaks or drips on the garage floor and the exhaust doesn't smoke.
I took the air filter out and sure enough there's been some oil in there thru the breathers but not very much. There was some oil film on the inside of the throttle body but not a full drop to be seen.
So, is it normal to lose/use/burn 7 ozs of oil in a thousand miles?
#518
#519
#520
Oil Light coming on
Add my name to the list of people having problems with the oil light coming on their M8. Have had my M8 for about 5 weeks and it has been in the shop over 2 weeks now. First time it went into the shop was for blow by. Turned out to be a bad O'ring in the push rod tubes. The next day after getting the bike out of the shop the oil light started coming on. It comes on when the bike is idling after riding 20 plus miles. After calling the factory, the dealer order a replacement the oil sensor. The next day after getting the bike out of the shop, riding 20 plus miles, the oil light started coming on again when the bike was idling. Took the bike back to the shop and the dealer consulted the factory again. Let me know if anybody else has heard this from their dealer, sounds like BS to me. The dealer called me yesterday and left a message on my voicemail saying the factory now has a new redesigned sensor and they are shipping it to the dealer. Ok, maybe an oil sensor they redesigned since last week or maybe an oil sensor that doesn't come on at idle or maybe a dealer that doesn't want to take the time to find out why the bike has low oil pressure? Ok, it's possible there is a new redesign oil switch that just came out and the original switch was a faulty design, but to me it sounds like a load of ****. Has anybody else heard this?
