Anyone doing the breather bypass on your M8?
#331
Like I said earlier, if the H-D engineers didn't have to put that **** back in there they wouldn't. I bet they will agree that the best place for that **** is any where but in the intake.
Sam D. (01-13-2019)
#332
#333
A question for those of you that have installed cans that have to be emptied. Why? Why not run it under your bike and to the ground?
The amount coming out is negligible. You will run through 5 times what comes out in a couple hundred miles. (Those numbers are just WAG so take a pill)
borrec (01-12-2019)
#334
Oily Underpants!
The pipes are called Breather pipes and not drain pipes for a reason! They breathe air with a small amount of oil vapor which requires vacuum to assist the breather function,reduce the casing pressure,and add to the upper cylinder lubrication.
Most importantly for the emissions control,it burns the the emissions within the combustion process and ensure it all passes through the exhaust.
Any attempt to close,catch or restrict the pipes or remove them from the inlet vacuum will collapse the system.
The yellow gunk is an externally manufactured emulsion of oil,air and water when they are trapped mixed and heated together as result of this or any other restriction.
#335
Harley did not invent the system.More vehicles than you can imagine breathe out of the tappet covers through an oil restrictor directly back into the intake.Dont suppose these guys ever saw or worked on an oil bath air filter or an oil soaked paper filter either?
FunHuman (07-31-2021)
#336
1) the system does not require vaccum to pull the pressurized air from the case - the air is pressurized and drives itself out.
2) the vacuum does nothing to reduce case pressure.
3) the vapor does nothing for upper cylinder lubrication. That is not how 4 stroke gas engines are designed. It's not a 2 stroke.
Again the introduction of EPA mandates is the only reason these gasses are directed into the intake to be burnt. Not because of a system or performance dependency. The system runs fine without it.
Bottom line, the breathers only point into the intake as a convenient place to dispose of the escaped gasses as to not hurt the environment.
Point of reference, older (before EVO) 4 stroke Harley engines did not have breathers going into the intake.
These gasses exited the bottom of the engine case (without vacuum) and went either into the primary or back to the oil bag or sometimes the ground.
That all said, does it matter? No. The engine does not care. You may care (about intake, valve, and piston cleanliness), and that's alright. America.
Jeff_S (01-12-2019)
#337
The EPA is an enemy of the cumbustion motor
They would rather it was outlaw’d
They don’t care that their solutions hurt your motors. Take ethanol fuel into consideration
Manufacturers were forced to figure out how they could keep that crap from
destroying their engines.
aten years!
That what I give the combustion motor. Then its all electric from there.
gasoline will sell for pennies a gallon for a very long time before the stock piles are used up. So let them do what they will.
Just hang on to your bikes. Or better yet? Start collecting if you can.
aten years!
#338
I've been following this thread and some of the information/opinions are laughable. I subscribe to the external breather group and have been riding a HD since 72, well before the time when they started to vent the crankcase into the carburetor now throttle body. I simply vent to the ground and can also confirm that none of the vented oil ends up anywhere on my underside/saddlebags/tires. Granted I'm currently riding a 14 FLHTK so maybe the M8 vents more oil than the twin-cam 103 but I wouldn't think so. I think what really deters most folks from doing this mod has to do with warranty because it is illegal to modify an EPA requirement. Also I felt that it would be better to not have hot oxygen deprived gases being pumped directly into my stage 1 cold air intake..
#339
Yada,Yada,Yada, Fake News.What is laughable is those of you that think you know better about breathers than the designers!
You think that the Yellow gunk,snot, or whatever you call it comes out of the engine? Notthing that comes out of the engine is harmful to the Bike but if you stick the pipe up your nose it will kill you.Your stupid attempts catch vapor restricts the expulsion of gasses which emulsify the oil and water.At any restriction point becomes a paint factory just like your nose when you have the Flu!
You do it your way,I'll go the Harley and the rest of the world way!
#340
Peter Quinn (01-13-2019)
