Anyone doing the breather bypass on your M8?
Old 01-16-2019, 12:34 AM
Peter Quinn's Avatar
Peter Quinn
Peter Quinn is offline
Are you guys blind? If he keeps the breather pipes facing up and reduced from 1 to 2 pipes running over the top of the sngine the ridiculous carbon build up will damage the engine within 2000 miles if left unattended!
Should I take this bike down to the Dealer workshop and avoid the cost? No Ill just do what they recommend on do on the hillbilly threads,leave the cause dangling in front of my face to go buy a aftermarket 117 upgrade?
You guys with your stupid breather mods and tin cans are the cause of his problem and he will pay for it with engine damage.
Arrogant enougth to go against quackery and go with the product designer.Yes any Day!
  #372
Old 01-16-2019, 01:30 AM
2018 lowrider M8's Avatar
2018 lowrider M8
2018 lowrider M8 is offline
I really do think Peter Quinn is here to just stir up people and create as much confusion as he can,sounds like he is the confused one good job Peter Quinn keep up the uninformed Opinions
The following 2 users liked this post by 2018 lowrider M8:
lrcormier (01-16-2019), Softy 103 (01-16-2019)
  #373
Old 01-16-2019, 06:31 AM
lp's Avatar
lp
lp is offline
Received 2,722 Likes on 1,547 Posts
This guy is a troll. No one can be this stupid.
Why is it that the two most active members from Australia are crazier than hell? I mean straight up nutz. Is it because they're upside down all the time?
Edit: No offense to Australia. We respect you guys, but might want to check over your shoulder every now and then as those two are walking your streets.
  #374
Old 01-16-2019, 06:37 AM
Cazador's Avatar
Cazador
Cazador is offline
Member
Received 3,323 Likes on 1,853 Posts
Originally Posted by lrcormier
Most of us understood your post and what you discovered prior to any mods. Peter Quinn obviously has issues, it's obvious his only mission on this forum is to create animosity and I find it's best to simply ignore any useless post of his. Thanks for inputs.
I think Peter is one of those fanatic global warming/climate chang characters. He believes that it's good that we use efficient transportation like motorcycles but to intentionally add to global warming is disgusting.
I am probably wrong but it's a theory.
The following 3 users liked this post by Cazador:
lrcormier (01-16-2019), Peter Quinn (01-16-2019), Softy 103 (01-16-2019)
  #375
Old 01-16-2019, 06:52 AM
Softy 103's Avatar
Softy 103
Softy 103 is offline
Talking
Originally Posted by Softy 103
What an ARROGANT ***!!!!!!!!
I'm changing this from" ARROGANT" to DUMB
  #376
Old 01-16-2019, 06:58 AM
Fat11Lo's Avatar
Fat11Lo
Fat11Lo is offline
WOW this thread has taken a turn south
This is what I did on my 17 CVO Street Glide. HPI V2 air cleaner
Drilled and tapped the spacers 1/8" NPT, installed the fittings
Installed everything and torqued to spec, used a transfer punch to mark the breather bolt, and then cross drilled the breather bolt 32nd up from inside diameter of bolt, made sure the holes lined up when installed and torqued
Installed ends on hoses and ran to the ground
  #377
Old 01-16-2019, 06:59 AM
splattttttt's Avatar
splattttttt
splattttttt is offline
Lets not condems everybody else by comparing that idiot to the reat of the world. He’s just that on his own
  #378
Old 01-16-2019, 09:51 AM
Fullbore55's Avatar
Fullbore55
Fullbore55 is offline
Received 2,632 Likes on 1,226 Posts
Fat11Lo, great job! Unlike some bypasses, yours should work with any AC, including HD heavy breather. Thanks for sharing.
  #379
Old 01-16-2019, 07:30 PM
Bowhunter8607's Avatar
Bowhunter8607
Bowhunter8607 is offline
Dr. Quinn seems to think that by venting the crud and oily air outside of the engine instead of putting it back into the cylinders to be burned somehow makes more crud build up on the pistons. Maybe he thinks the breathers suck air into the engine instead of expelling the dirty air from the engine case? He is obviously confused with his head up his ***.
Here you go Dr. Quinn. Read up and educate yourself on the subject. Maybe you'll actually post something useful here other than the BS you already have.
http://www.dkcustomproducts.com/over...ystems-ebs.htm
  #380
Old 01-16-2019, 11:36 PM
Peter Quinn
Default Dr Quinn the medicine mechanic.
Awe,shucks guys you found me out! I'm actually dumb and blind! Sure I thought those Pistons looked like the worst burnt toast with marmite spread I've ever seen. Suppose it's all good then? So it's off to the optician for me!
Yes it's me who is an EPA conspiracy theorist so I'll just have to reform,sorry.Truth is I've never been one to buy Snake Oil or pirate parts. I really don't care about the jibes.Truth is I'm not with you,I'm really with Harley!
Quick Reply: Anyone doing the breather bypass on your M8?
