Milwaukee 8 speed limited?
Old 12-09-2016, 07:39 PM
Steve Cole's Avatar
Steve Cole
Steve Cole is offline
HD EFI Guru
Received 3,458 Likes on 1,593 Posts
The stock M8 Touring bikes are Speed limited at 176 KPH, once the limiter has turned on it requires the bike to slow to 171 KPH to turn power back up in the engine.
176 Kph = 109.36 mph
171 Kph = 106.25 mph
There is also Torque management that starts to control the throttle blade as you approach those speeds so it doesn't hit real hard on the limiter.
Old 12-09-2016, 09:41 PM
roadrash3's Avatar
roadrash3
roadrash3 is offline
I was pretty sure all the dyno's are 5th gear runs and thats where it is limited. I thought I had heard that 6th gear was not limited at that speed.
Old 12-09-2016, 10:53 PM
CVO SG's Avatar
CVO SG
CVO SG is offline
Are the CVO's the same or are they set at a higher speed?
Old 12-10-2016, 05:36 AM
Hasher's Avatar
Hasher
Hasher is offline
My M8 seems to be speed limited by the right handgrip and my desire to keep my license.
Old 12-10-2016, 02:06 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
They are all the same for 2017 for the speed limiter on the M8. Also you can get mislead with dyno graphs if you do not know the gear there run in. 6th gear will typically show 5 hp and 5 ft lbs more than when run in 5th gear. The engine is not making any more its just the dyno causing it. Between dyno to dyno differences and people playing games with how they dyno you have to read between the lines many times.
Old 12-10-2016, 02:30 PM
IdahoHacker's Avatar
IdahoHacker
IdahoHacker is offline
Received 2,961 Likes on 1,687 Posts
...Also you can get mislead with dyno graphs if you do not know the gear there run in. 6th gear will typically show 5 hp and 5 ft lbs more than when run in 5th gear. The engine is not making any more its just the dyno causing it...
6th will give you higher readings, but it's been my understanding that this is due to the different power paths through the transmission, 6th being direct drive, and not due to the dyno causing it.
Correct?
Old 12-10-2016, 02:35 PM
rjjj629's Avatar
rjjj629
rjjj629 is offline
Thanks for the info. Can you tell us where you got it?
Old 12-10-2016, 03:32 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Correct?
Some would like you to believe that but it is not true. One of the tricks people play with the dyno is to sit on the seat or not sit on the seat, that will change the power readings too. Many many tricks and it has ruined the purpose of the report IMHO.
Old 12-10-2016, 03:33 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
I took it out of the calibration setup points in the calibrations that get installed into the ECM.
Old 12-10-2016, 09:58 PM
Heatwave's Avatar
Heatwave
Heatwave is offline
Member
Received 1,077 Likes on 638 Posts
I don't believe this is factual.... or at least completely accurate. There WAS a 4-5hp difference berween the 6th gear vs 5th gear dyno runs on my 2017 stock CVO Limited 114. However, after upgrading with the 117 performance kit, Street Cannons and Pro Street Tuner, the 5th and 6th gear dyno runs were absolutely IDENTICAL other than hitting the speed or rpm limiters at different times. The graph lines were directly on top of one another. Thoughts???? Torque management coming into play with the pre-programmed Street Tuner map??? I know the tech and was "in the room" during all the runs. Straight up dyno runs.
Quick Reply: Milwaukee 8 speed limited?
