Intercom Help Needed
So, I got the headsets (plug in type) installed in our helmets. I have the intercom feature turned on. We can hear music. When we speak, the music volume automatically lowers, but we can't hear each other's voices through the earpieces.
Any ideas on what I am doing wrong? As always, thanks much Emil |
Turn the intercom voice volume up. When you talk, the other person turns their volume up. The boom system has a volume control for each and every function.
As posted above you have to be speaking when turning the volume up for each person. Just start talking and at same time hold volume button up and you'll see the increase on the screen.
Is that for just the first time ever, first time for that ride, or each time you talk?
Originally Posted by Emil Wide Glide
(Post 15901456)
Once you have them adjusted, they should stay that volume until adjusted again. You probably can't hear them because the volume is turned all the way down... |
Start talking and turn the intercom volume up. There is one adjustment
for the front - left toggle up, and one for the rear - passenger volume control. Once you have this set, you may discover what the rest of this is about. I have a 2017 Harley Ultra Classic, so there is no CB, and no PTT installed as standard options. I don't want to have the CB installed only to discover the same problems. We have J & M helmet speaker system, awesome thanks, and use it for limited communications, through the terrible VOX intercom, that can never set at the right level. It's either too, or not sensitive enough. I have been trying to get the right level for 80,000 miles and 2 bikes! While listing to music, the vox is suppose to get the message that we are trying to talk. The problem, it frequently transmits half messages then switches back to music. The typical conversation: She: "the cows" me: What? She: "at the cows!" Me: "Sorry I didn't get all that" She: (loud) "Look at all the G.D. cows!" me: "Where?" She: "en we get home" me: "What?" She (screaming) "lets just talk when we get home!" So at present, my solution is to turn the vox sensitivity all the way up, so the music does not play at all and we can talk until the cows come home. Option two, is to turn the vox off, listen to the music, and yell at each other when we have something to say. Does J & M have anything to fix this problem? |
The key is to follow the directions above and do it before taking the bike out. You will have to make some adjustments to account for wind that will activate the mic on either of you.
The music will automatically cut out to allow for mic communication and phone calls if you have your phone blue-toothed to make and receive calls. |
Intercom problem
Hello, I have the same problem with my intercom, I can hear music, I can make phonecalls but I cannot communicate with my passenger.
I tried talking and turning the intercom volume up, as suggested in this thread, but without result. Music keeps on playing. What am I doing wrong? I own a 2017 Ultra Limited. Thanks |
Maybe this link can help you:
Originally Posted by dcfatboy
(Post 18300978)
So I will have to do it with the voice activated Intercom and the wired headset. Our headsets are 20 years old, works great on my 1989 Ultra Classic. I have already replaced the cables for new ones, the new cables have smaller plugs for the helmet unit so I had to put on bigger plugs. But I think the cables and helmet unit are not the problem because I can make phone calls and hear the music. |
© 2024 MH Sub I, LLC dba Internet Brands
