Oil pump changes..
I have one of the newest pumps now. There is another bulletin now that tells the dealers not to use any pumps that were made prior to a date certain, that is on the box. I do not have the date but it is coming. There are different versions with the same part number on them so there is also a marking system with machined dots in the pump your suppose to look for. At a quick glance they have changed the suction side machining that times the gear rotor to the pump housing and it appears they are hand finishing to the gear rotor height by trimming the casting to match. This is going to reduce the end play on the suction side.
So the bikes built up to this point, you will have one of the "bad design" pumps? That is a lot of bikes, I wonder if HD is going to replace only those having oil light/sumping issues. Is the latest iteration to fix the oil light/pressure issue or sumping, or both? I worry about too little oil(even though not tripping the light) since new, that would not be good for bearings/bores/rings. Now I am hearing of badly bored jugs that have blow by, some out of spec by .007 and no hatch marks in bore. I could pull my plugs and look with a bore scope. I shouldn't be worried about any of this with a new bike. I don't understand how HD can screw up the basics after 100yrs of experience VERY poor QC.
The way it was told to me and the way I read it. The newest pumps are to be used on all bikes 107, 114, 117 not only Stage III and IV. They are no longer doing the mark the pump with dots any longer it is now strictly the date code on the box as the part number did not change but the Oil Pump did. Kind of chicken $hit if you ask me, there should be a new or revised part number anytime it is changed!
The way I read that is the redesign is for sumping issues, that is all it says to check for. It does not mention oil light issue? I still wish I knew what caused those initial oil light issues.
It's my bet that the latest pump with the no change in the part number is nothing more than same previous pump but they set the scavenge pump side clearance.. They probably keep the same number because they are hand finishing them an not wanting to change the label. I don't condone what they are doing but am trying to explain why in their eyes, the number did not change.
