The Fix Is In!!!
#31
#32
Stone - please PM me your PayPal address. I'd like to make a donation to the cause. I've got a good wrenching background but this machining stuff is way above my head. The work that you and Steve have done is above commendable while H-D sits around with a team of engineers with limitless resources that can't solve this.
Your efforts are much appreciated.
#33
04ctd (03-01-2018)
#34
#36
The following 15 users liked this post by $tonecold:
04ctd (03-01-2018),
Billsbuffalo (02-25-2018),
bzb123 (02-23-2018),
CageyKG (02-22-2018),
crusader1xxx (11-28-2018),
and 10 others liked this post.
#37
I expect no more than 0.001" runout from you and for you to deliver it in 2 weeks for the cam testing. Since your just down the road a little should be no big deal
#38
I would like to offer a little more insight . Because of thread tolerances there is a need to fit a nut or adapter with a snug thread to fit whatever the measured thread on the shaft was .Once the thread fit was determined, a part could be made so that the thread ( with the required dimensions for a snug fit ) could be turned or hardened and ground so the seal had the require running finish and all other faces of the nut or adapter were concentric .There should be little run-out on a shaft that close to the bearing so that shouldn't be a concern.I don't know why Harley didn't use a sealed bearing there, unless there was concern of a vacuum buildup in the primary and left the bearing open for a greater balance for pressure between the primary and the transmission.The primary vent hole ,and a seal to the bearing were excellent observations .
#39
I ordered the nuts last night.. McMaster says they'll be here today.. When I cut the nuts, they will be done on a single point threaded mandrill that is first cut and not removed from the lathe. This means that that threads on the mandrill are exactly on center, 0 run-out.. The thing is that we don't know how straight the threads are cut on the ends of the shafts in the tranny.. They are probably cut before heat treat so they might be off a little.. Anyways we'll see how close I can get.
#40
