M8 Cam Bearings
SE High lift cam bearing
For those of you upgrading your cams in the M8 spend a little extra and replace the stock cam bearing.
Pic left is SE and right is stock one taken out after 11k miles.
Also, be aware a lot of the M8's are having issues with the plastic lifter plate that holds the lifters in place. They're cracking and allowing the lifters to spin, thus damaging the cam.
The bearing exchange process can easily go wrong so it is better to leave well alone and go with the bearing which is tested and working in your Bike.
To be sure some who have never changed a spark plug will disagree with this but I really don't care!
The SE inner cam bearing has always been reserved for the high lift cam,special valve spring applications and are included in the stage 111&1V kits only.
The following 2 users liked this post by lp:
Campy Roadie (04-26-2019),
metalb00 (04-02-2018)
