M8 crank breathers are crap
When I first bought my bike oil carry over was no problem. Then the rings got seated and the weather got hot. Now, I am getting oil carry over on every ride. Have already thrown away the original air filter. After cleaning it a few times it was so oil soaked it was worthless. Lots of others are reporting issues. One member had his umbrella valves replaced and it made no difference. Harley better not have a problem, warrant wise, with people venting to atmosphere. Because we shouldn't be expected to buy new air filters every 3k miles.
I'm wondering of some of these issues with different models aren't a result of the terminating end of the vent tubes not being positioned far enough into the inlet of the throttle body. Thus the upstream accumulating oil vapors drip into the breather before it can get sucked into the intake. Just a theory as I haven't visually seen all of the tubing configurations on the different models. I know that mine has a factory tee joining the two tubes together with a single outlet into the throttle body inlet. In other words ,maybe a short extension of the tubes might remedy what is accumulating in the breather.
The following 2 users liked this post by TriGeezer:
George Vee (08-16-2018),
Rokinrider (01-18-2021)
Manual says clean the filter every 5000. I've heard Harley techs say do it every 1500. Personally, I've added a small canister inline with vents. In the canister, I've used a foam fuel filter for a lawn mower. The canister slows down the air because of the larger cross section, and the filter does a good job pulling out the oil. Mostly on race bikes. Essentially a fuel filter would work too. Just have to make sure any condensate drains down.
BigDogIdaho (01-18-2021)
Yes, don't want this crap going into your engine.
Getting it out increases performance, helps with cooling, and increases engine longevity.
LINK to external breather systems for Twin Cam and M8 engines.
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Cristy
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
