Photos of piston and valve with stock crank vent system.
Every motorcycle built in the last 30 years or so will have a similar setup. The difference is the air box, Harley is still using the exposed open air intakes, most other manufacturers have switched to an enclosed air boxes with separate filters designed to control the oil from the breather (even then oil still makes it to the intake).
Captain Obvious checking in, but also believe the old addage of "blowing the carbon out" still applies with these, and need to wring them out often..sometimes we get lulled into infatuation with all the low and mid range torque and get lazy on the top..try to exclusively use Chevron as well, Techron is a proven additive
Assuming you meant you can’t convert breather system until end of warranty. If so, not necessarily true. You can direct breather snot into catch can inside AC housing. No need to drill hole in backplate.
stixvrad (08-21-2018)
The mod I made to my breather's been working great. It vents to a large container that lives in the stock are cleaner housing.. After close to 1,300 miles I got maybe 1/4 oz of mostly water with some oil mixed.This is a 2 ounce shotglass I poured it into.
However you vent it, IMO you just CAN'T let it go into the intake..
