How to change clutch action - 2019 Clutch part installed in a 2017
#41
#42
#43
#44
#46
#47
Another Old Timer (11-19-2018)
#48
#49
Thank you for the posting
I have a 2018 Street Glide Special with the same clutch feel issue. I like to Harley about the spring seat spacer for the 19 like you had mentioned and installed it today. Definitely better and seems to shift better with less clunk. Thanks for the heads up very satisfied
Max Headflow (11-17-2018)
#50
Just finished installing the damper seat part number : 37000295 into my 2017 Road Glide Special. The result is magical.
Strangely, I seemed to have 2 types of friction plates (narrow and wide) like the manual says, and 2 types of steels (narrow and wide) but I also had a steel that was smooth located at the interface of the pressure plate pack not mentioned anywhere.
