Yes sir. Picture not so good but I’m reading exactly 15.25 inches for the stock clutch push rod.
Thank you. Did you happen to measure the MCC one before installing?
I’ll certainly post my results when mine arrives, but I’m curious what you got. Note I don’t plan on installing mine unless/until I need it, which I’m hoping is never!
Didn’t actually measure it but placed them both together on work bench on their ends. Exactly the same length. Clutch works identically to before install.
I never had any transfer either but I got sick of checking!
You pull the entire side case and do the primary fluid change at the same time? I sent an inquiry for one myself. GTG at 3500mi for now, but I'm running on a FLHCS and haven't had any recalls either.
Why would you pull the entire side case to change the fluid?
