Any reports of sumping on bikes
So I might know a thing or two.
If it is a defective filter problem it would be hard to diagnose if it was a random defect in the filter. A bike that has sumped would need to have the filter flow tested if indeed such a flow test rig is available.
HD should look into that.
Any bike that sumps, have the filter sent in for testing to determine its functionality.
Chandler,
Check this diagram.
https://www.hdforums.com/forum/milwa...l#post15655377
If the oil filter clogged up, filter would go into bypass mode, to continue pressure feeding the engine the oil it needs.
Check this diagram.
skid_pimp (06-16-2019)
Chandler,
Check this diagram.
Check this diagram.
Chandler,
Check this diagram.
Check this diagram.
Back in the mid eighties, I was at the Harley dealer in Lufkin, Tx. He got a call from a customer that was stuck on the side of the road. He asked me if I wanted to take a ride and I obliged. Long story short, the customer had used an automotive filter on his EVO motor (FXR) and it clogged. It either didn't have a bypass or it had one that wouldn't open with the pressure the EVO was pushing. It stalled his motor and it wouldn't run. Changed the filter, jump started the bike and he was on his way.
