2017 M8 Touring Service Manual
Silentgreyfellow (09-12-2019)
If you are interested in standard torque values I'm sure a google search will yield the results you are after. It is all based on the diameter of the fastener and the Grade of the bolt( IE grade 8) ect., the only things you might need the book for is if you need to see the torque sequence for like the heads or rocker boxes. Remember if you are just changing mufflers use the German Torque aka goodantite. It's not rocket science.
unclerog (09-12-2019)
