12” la chopper twin peaks
I put the same bars on my 19 Street Glide a couple months ago. I used the stock clutch and brake line but did use wire extensions, recommended by my parts guy at the dealership who had 14"s on his Street Glide. Don't think the extensions are really required but I used them since I had already bought them.
I would recommend removing the tank for access to the button panel and I would remove the fender (4 bolts) to avoid any accidental damage, they are terribly expensive. I am speaking from experience.
I took my plugs apart to make it easier to run the wires. Some say you don't have to, I did it anyway since I already have the experience doing that and it was no big deal.
Just want to say thanks for all the tips and advice, finished up this evening. Followed the factory 47 video and had plenty of length for the 12” bars without needing cables or wire extensions. I did replace bushings with poly and drilled and tapped factory clamp with a set screw. All good and rolling again. Took probably 7 hours total, taking my time. Toughest part for me was de pinning connectors. Thanks again all for the help.
TexasMotorcycleRider (09-16-2019)
bpd138
2014-2023 Touring Models
31
05-24-2019 11:25 AM
BarleyW83
05-05-2019 09:50 AM
Coastal_Moto_Man
Vendor For Sale Classifieds
09-23-2014 10:22 AM
