Replaced head gasket and now the engine won’t start. Help!
strych9 (12-02-2019)
Got it pulled apart today. Definitely had the pushed rods switched and the intake valves are bent. Did a “poor man’s leak down test” and shined a light through the intake runner and could see light around the intake valves. And they had marks on the front of them from contacting the piston. It doesn’t appear they made a lot of contact though. Just a kiss. So I dropped it off with my local dealer. They think they can just replace the valves. We will see.
slightly lower compression? edit, you said benefit, I read 'difference' at first..
I think the 0.030 would be better for a tighter squish area giving more turbulence and less chance of preignition vs the 0.040. I don't know what the stock thickness is though.
If you have pulled both heads, going with the .040 gaskets probably won't require a different tune. It only increases the compression to 10.1:1. The .030 gaskets will get you to 10.3:1 compression which could be enough to require a different tune. Someone with more tuning experience than I have could really answer this question better than I can. If you were going to install a cam while you were doing the heads, then I would for sure go with the .030 gaskets. The increase in compression and the tighter squish will make a performance difference.
Are you doing both heads? If not, you need to stick with a stock gasket to match the head you haven't pulled.
