M8 Cam Swap, 8 Lobe Oil Pump install, S&S lifters / lifter cuff install, using Fuel Moto adjustable pushrods
Knowledge is king, set yourself up for success. There are service bulletins that change specific procedures written in the service manual. Before wrenching inside your engine it is wise to obtain them from your service dept. Harley changed the Cam support plate tightening procedure a long time ago.
Can you elaborate on a revised Cam support plate procedure?
This is the newest SB I have, it is not current, contains outdated oil pump information. . I do not know if the support plate procedure is current or not..
