Primary inspection?
Primary inspection?
So its snowing outside and am looking for things to do on my 2018 FLHTK. She has 30k mikes and was considering removing the primary cover and having a look.
The bike has no problems whatsoever. No fluid transfer, no noise and shifts great. The bike has had redline fluids since new.
So am I wasting my time or should I go ahead and inspect?
definitely go for it ..in the same boat..wife is watching Hallmark Christmas movies, I just finished rearranging the silverware drawer according to utensil length and it's raining
The following 2 users liked this post by sandrooney:
Campy Roadie (01-18-2021),
TriGeezer (12-25-2020)
Harry good Luck ! Let us know what you learn while you have the belly of the beast opened up,,,,don't leave us hanging like some OP's do,,,P
Harrybeerbelly (12-26-2020)
so if you're planning on keeping this bike for many years and piling on the miles why not just put new clutch friction plates in while opened up? thinking they can't be all that expensive, guessing maybe under $100, then you start out new again since you're already in there and gives you more to play around with as a Christmas present. can't imagine they would need replacement though with that low of miles if you're not abusing it..so that might just qualify as a waste of time and money
Opening the primary for no reason is a waste of time and money.
Why don`t you look in the service manual and see what inspections are due at 25K?
Pretty sure you will see that it is time to inspect, repack and adjust steering head bearings.
If you gotta do something, do something that needs to be done.
The following 7 users liked this post by Dan89FLSTC:
Bigt001 (12-26-2020),
Erilflynn (12-28-2020),
hattitude (12-27-2020),
Keithhu (12-25-2020),
and 2 others liked this post.
