Had the sumping issue on my 2018 FLHTK. Dealer installed the vent kit at the 1K service. Appears to have worked.
The vent is installed to eliminate the problem of transmission lube migration over to the primary, it has nothing to do with sumping, that is a engine issue.
I spent 44 years as an aviation mechanic, and I find that the modern Harley service manuals are well written and laid out, the earlier ones do not compare to the later manuals.
so you took your new bike in for sumping and they installed the fix from Harley for trans fluid transferring to the primary? more than one person confused here
I noticed power loss in certain situations and mensioned it to my dealer. They found oil in the crank position sencer and replaced the oil pump with the new 2020 8 lobe oil pump under warranty.
2018 Ultra Limited M8 107
Not been able to ride it because of weather but did some upgrades , one being Screaming Eagle High Flow air breather .
when took off the OEM there was quit a bit of oil on the inside of throttle body ..
Have read where some claim that to be a sign of sumping .
So thought I would ask if any had had oil pump issues .
Like Keithhu and others have said, this is not a sign of sumping. Contrary to the owners manual, try keeping your engine oil a little low - about half way between the full and add marks (about 4 quarts or just under). That will probably take care of it. If not, you can install an external breather system,,, like that from DK Customs or make your own There are a lot of threads here about EBS..
I have found the search function to be a waste of time in most cases..
I haven't had a lot of success with the search function here either. I just search Google, and it usually leads you right back here to the answer that you're looking for.
Actually I do the same. Use google and end up back on this forum but on the right threads. That being said there's nothing wrong with asking again as riders always have new experiences to report on.
My apologies....having one of those days for 2 days now. I did manage to find the battery tender for my motorcycle this morning.
I posted the 'fix' to a different issue. I need to pay better attention ! This had nothing to do with the topic being discussed on this thread. First beer's on me if you ever get out to Vail.
Yup....my fault for posting and not paying attention. My apologies.
