Dielectric grease - how much in a spark plug boot?
M8 ... when replacing the spark plugs how much dielectric grease is appropriate and where to put it ... on the plug porcelain or just up on the cap in the boot or ???
I've been getting a random missfire (with an accompanying snapping sound) after changing my plugs, I'm thinking I may have overdone it with the dielectric grease, seems to be mostly within the first few miles of startup and when under acceleration ...
Most likely you either cracked a plug when installing it or you don't have a wire clipped on all the way (excess dielectric grease can cause a hydrolock in the boot )
