Fan assist oil cooler never seems to come on?
Update: Fan works fine.
Looks like I have joined the ranks of the "false alarmists". I was so used to my 2019 Road King's fan remaining on for a few seconds when killing the motor that I just assumed the Road Glide would do the same, and was concerned when I never heard it after shutdown. But I confirmed it runs by feeling around that the fan was indeed blowing during my pleasant 92 degree ride this morning.
Just for your amusement, this also happened today while heating up the oil for my "hand job" experiment: When I pulled off the highway to check the fan after a nice 30 min straight 85mph run, at the exit red light my motor started idling strangely. Of course since I was thinking in "paranoid mode" I immediately thought "sumping" but a blip of the throttle brought it to normal idle, which then pretty quickly started to chug again. Thankfully I came to my senses and remembered "EITMS"... But I always disable it? Weird... Then I realized I must have enabled it when testing the fan. You test the fan by holding WOT for a few seconds with ignition on, engine off. But the first time I tried the test, I forgot and rolled off the throttle, which is exactly how you enable/disable EITMS. So checking it on my info screen, sure enough it was enabled. Whew. Once I got off the bike to feel around the fan, I also re-disabled it.
So all is well in my world now...
Thanks for the "reach around" suggestion Steve.
The following 3 users liked this post by Mchad:
At least yours is a dry heat. Try 90's with 90% humidity and blazing sunlight. It's literally the worst. Your perspiration doesn't evaporate to cool you. You just get soggier and soggier until you eventually pass out and die. I would welcome a few days in the desert at this point.
Yes sir, you are correct about that.
Received 4,078 Likes
we'd kill for your rain out here in Oregon..driest, drought stricken and record temps, 117 recently and fire season..again... ..we have the largest fire in the country going on and it's causing air quality pollution in NYC!!!
after the pandemic, all the fires, ice storms..this is our theme song
https://www.youtube.com/watch?v=wa43FNUdpU8
And Mchad, glad you are all set. Now I know if my fan doesn't run for a few seconds after I hit the kill switch, like it did on my last bike, I should be good. But I will be performing the "reach around test", just to be sure!
Mchad (07-23-2021)
I’m down to FL quite a bit but real picky about the time of year. Makes for a whole different experience.
Planning on owning something on the gulf side in the next year or two, but gotta keep my NJ getaway as well to provide the occasional escape.
That didn’t take long!
Old Sport (07-23-2021)
The new bike with 1051 miles is in summer storage. The heat takes all the fun out of riding for me
I installed that same fan on my 17SGS, and like you it would come on with the WOT test with bike off course, lol, and I could hear it fine. The only confirmation I had it actually worked when riding was coming home from a ride, pulling in the garage, throw it in N, and get off the bike to put my hand down there, sure enough blowing air. Now my 20RGL, when I shut it off, if it's been run in hot enough temps, the radiator fans stay on may 20 seconds after shutting it down. So definitely sounds like yours is working as advertised.
I installed my fan assist oil cooler 62700204 on my 2020 Road Glide Special, and flashed the BCM using my Diag4bike (digital tech-lookalike). However the fan never seems to kick in. I’m in Florida, so it’s hot. I do run with my LoveJugs fans on pretty much all the time, but even when off I don’t get fan.
The fan is definitely enabled, and will come on if I do the diagnostic check of turning on ignition and with motor not running, hold WOT for a few seconds. The fan comes on just fine. I even went back in and unchecked the fan in the BCM settings, and confirmed the fan DOESN’T come on using the previous test. So I set it back on, tested again and it blows. Just not when riding.
So like I said, it’s hot. Florida hot. I got big 128 jugs. More hot. A big cam. Even more hot. Why the heck wouldn’t the fan come on?
I had the stupid H-D oil temp dipstick but it only seems to work when the bike isn’t hot. Useless. So I don’t actually know my oil temps, but while I love the stuff, i doubt my Red Line 20-50 has super miraculous oil cooling properties…
Any ideas? Tx.
Any ideas? Tx.
