Having a hard time nailing down what the rise and pullback are for OEM bars for a 2020 and up streetglide special.
I did search through the forums and got conflicting measurements.
HD has their own unique method for measuring pull back (tip to plane), and rise (tip to base).
The OE bars on my 2018 (same part number as 2020+) have a pull back of 6.5", and a rise of 10.5".
I had no idea they were 10.5 rise, You came through again! I found some reduced reach bars by Fatbaggers 12" pullback, I can reach stockers but my arms are almost locked.
You can also pull the stock bars back to make reaching them easier. There is a location pin under the riser clamp that can be knocked down flat to pull them back further if needed. I knocked that pin odwn on my 17 when I put some KST bars on, as I too was having to stretch my arms out completely and was almost leaning forward.
Street Glide, or Road Glide? If you try pulling the bars back on a Street Glide, they'll hit the tank.
