Intermittent stall w/ P2300, P2303 ECM codes 2018 Fltru
My '18 Road Glide Ultra (out of warranty) intermittently stalls, with P2300 & P2303 ECM codes. The 1st time, I replaced the coil (even though it tested ok), cleaned all grounds, checked continuity of ALL power supply & ground wiring to/from all 3 ECM connectors, & checked plug wires for chafing/wear/burns (no issues found, but replaced with SE 10 mm wires anyway plus new plugs). Started right up, ran great about 5 miles, stalled again, same codes, wouldn't fire. Went to get a trailer & some help to load it, and decided to try it again before loading on the trailer. Started right up! Rode it onto the trailer, rode it into my garage, started it several times over next 24 hours and let it idle, no issues. Decided to road test it the next day, only went 1/2 mile, stalled again, hasn't started since. Replaced crankshaft position sensor, no dice. Any similar issues out there?
thealien
05-28-2016 10:26 AM
dirtdobber
02-28-2014 03:26 PM
