Street Glide Rear Fender on Ultra Classic
Originally Posted by harley0711
most likely just $$$$$$$$
I would call boardtracker HD and ask Anthony + get great savings
2015 cvo rg ultra with 2010 street glide fender extension and kuryakyn bag extensions. And street glide uses the same plug that the tour pak uses on ultra so to get street glide tip lit up I had to splice. I used custom dynamic hole fillers on the street glide extension.
That looks good. I wanted to get the CVO ultra fender but it has the badge on it and an indention if you remove the badge. I already have painted fillers so thought that one day when I get the extended bags I could just add the SG fascia. The dealer is trying to sell me a European complete rear CVO fender for 750 bucks. They had it painted Vivid black though and I would have to have it painted Amber Whiskey which would add another 500 bucks to the cost.
Yes, the bags are CVO Style. Got them from a guy on the forums here.
The harness plugged in both ends no problem. The fender was from a 14 and my bike is 14 and the fender came complete. The guy that sold it used the harness on his aftermarket fender. One caution ordering, make sure they don't get you an "international" harness. Dealer ordered wrong one. Plus there is a rubber channel to keep the wires off the tire. You might need that. It is designed to run the wires through before the plugs go on the ends so I had to cut it lengthwise down the sticky side. So when I prepped the inside fender with alcohol, it stuck nicely and was secure.
