2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
DIY -AC Breather System - Way, Way Easy, and Cheap!
Old 09-03-2016, 06:24 PM
CJeep's Avatar
CJeep
CJeep is offline
Default DIY -AC Breather System - Way, Way Easy, and Cheap!
OK, there are a bunch of threads on this kind of thing, but this was sooooooo easy, and super cheap.
Nod to DK Customs, as I had their breather kit and AC on my Dyna - got a good feel for things from that kit.
This is temporary. I'm going to get the DK Customs intake that hides under the stock cover - mine is a FLHP, so that "103 Police" HAS to stay. But I don't want to spend the $ on that right now, but my God how the TB was covered in a film of oil. Even after I cleaned it, like 100 miles later, when I did the DIY bypass, it was all oily again.
You need 4 things: 5/16 fuel line, small hose clamp, hi-temp RTV, and a breather. That's it. I had all of that in my garage.
Take the air filter off, RTV the hole the breather dumped into and set it aside to dry.
Take the stock T-fitting and turn it facing up. Put one end in the 5/16" hose, run the hose like in the pic. It's a snug fit, so nothing will move around.
Then drill a hole (I did a pilot hole and then a stepped bit, cleaned up with a round file). Run hose through. Sorry - dark pic
Turns out, my scrap hose was too short to put the breather down low where I wanted it, but no turning back now (remember, this is temp until next spring), so I trimmed it real short, and put the breather on. Since it was designed for 3/4" hose (it came with the DK kit from my Dyna, which used 3/4 hose), a bit of WD40 got it on snug. Probably don't even need the hose clamp, but of course, I put one on.
I kid of dig it there. So far, no oil spray on my pipes or engine. Running, the bike smells different. I'm certain it's the vented gases from the breather.
Bike runs great, but I am autotuning with the FP3, as it should have slightly changed the O2 content and temp of the air coming into the intake.
The following 2 users liked this post by CJeep:
DK Custom - ST (03-29-2018), madmat (02-12-2019)
Old 09-03-2016, 08:52 PM
Casper's Avatar
Casper
Casper is offline
Nice write up,
Would you happen to have the "police" insert part number?
Old 09-03-2016, 09:30 PM
CJeep's Avatar
CJeep
CJeep is offline
I can't vouch for it, since mine is a police bike, and came with it, but Ronnie's parts finder has 61300144 for the insert.
Old 09-03-2016, 09:38 PM
golfblues's Avatar
golfblues
golfblues is offline
Received 1,436 Likes on 876 Posts
Just put the DIY kit on my 06 and a custom optimized kit on my Heritage with a PM Supergas cleaner. Great kits
Attached Thumbnails DIY -AC Breather System - Way, Way Easy, and Cheap!-20160903_181336.jpg   DIY -AC Breather System - Way, Way Easy, and Cheap!-20160902_175428.jpg   DIY -AC Breather System - Way, Way Easy, and Cheap!-20160902_175447.jpg   DIY -AC Breather System - Way, Way Easy, and Cheap!-20160903_181443.jpg
Old 03-28-2018, 04:27 PM
IowaRandy's Avatar
IowaRandy
IowaRandy is offline
I know this is from a couple years ago... but was there any issues with the top hose going up instead of draining down?
Old 03-28-2018, 04:52 PM
BigMike's Avatar
BigMike
BigMike is offline
Received 1,570 Likes on 674 Posts
Mine is different than this setup but the Y piece connecting the two breathers is higher and there is no problem. There is a little pressure that moves the junk through the hose.
Old 03-28-2018, 08:57 PM
hbsoldier3's Avatar
hbsoldier3
hbsoldier3 is offline
Move the filter under the frame.
Old 03-28-2018, 09:44 PM
SSpeeDEMONSS's Avatar
SSpeeDEMONSS
SSpeeDEMONSS is offline
Nice. Not a fan of the filter but the rest looks clean. I never thought of that way when I did mine.
Garrett
Old 03-29-2018, 07:56 AM
BigMike's Avatar
BigMike
BigMike is offline
Yep, where he has the filter it's going to leak all over the engine. The point of the breather is to expel the vapor and oil mist without it being fed into the throttle body.
Old 03-29-2018, 08:12 AM
IowaRandy's Avatar
IowaRandy
Default What I did
Here's what I ended up doing. I will probably end up moving the breather under the frame if it ends up making too much of a mess.
hbsoldier3 (03-29-2018)
Quick Reply: DIY -AC Breather System - Way, Way Easy, and Cheap!
