Tricking the Boom Infotainment for better Sound Quality
This topic of conversation came up over in the audio forum so I thought I'd bring it up over here on the Rushmore forum to see if anyone else had any ideas on how to do this, or even if it's possible. As most people know, the sound quality of the Boom 6.5 radio is better when the switch is in the ACC position with the engine off. The DSP changes (removes bass) when the switch is on and engine running. HD did this to make the stereo sound better in the show room and to prevent the stock (cheap) speakers from blowing while riding with the volume cranked up, as I understand it. My question is... can the Boom 6.5 HU be tricked in some way to think the bike state is ACC position, engine off, even when the switch is actually on and engine running, thereby providing the "showroom" quality sound while riding? What triggers the HU to switch between the two "bin" files? Can that trigger be disabled?
04ctd (10-31-2017)
The key is to flatten the signal coming from the HU, not trying to get the same signal as in the accessory position. The bin file trigger can't be turned off, but an aftermarket DSP can be used to totally flatten the signal modification coming from the HU and allow an aftermarket amp to properly do it's job. The 2 most common DSPs also have built in equalizers. Amplifiers simply boost the signal provided to them - a crap signal in = a really loud crap signal out. The idea is to remove the falsely boosted signal, not recreate it.
04ctd (10-31-2017)
I am not certain there is a difference in the run position vs the ACC position.
Try this - put in run 0 don't start the bike. Listen. Put in ACC and listen - to me it sounds the same.
Now put in ACC, listen and next to run and start the bike - sounds different because the bike is running and you have other noise. Just my opinion.
The following 2 users liked this post by cycle7447:
SpringerRider (06-05-2018),
Steve Molander (05-30-2018)
HogPilot54 (04-19-2017)
I've toyed with the idea a little. The Boombox is getting a signal through the canbus that tells it the engine is running, not just the switch in the run position. There are only 2 wires.... can hi & low. (There are 2 others but they are not involved).
Filter out the signal & the Boombox will be fooled. I've had a couple of ideas, nothing really to speak of yet. I wonder if it might be sensing the voltage... lots more with the engine running.
I'm surprised Iron Cross Audio or the like haven't figured this out yet, maybe they don't know anyone wants it.
And I agree, sounds lots better with the engine off.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
