Adding inner fairing mirrors
Fairing mirrors - FLHTK
Just fitted these on my 2018 - very pleased with the results
BEWARE: if you are fitting yourself they are easy but, the instructions are a little misleading.
The holes to drill are clearly marked on the inside of the inner fairing but, what it doesn't tell you is that the holes need to be angled (use a reamer) otherwise the mirror will not fit snug.
The mirror mounting stud goes through at an angle, if you try to tighten without angling the hole you will snap the stud- they are plastic studs and do not take too much to break.
Just a little heads-up to help
+1 I put them on my 2011 Ultra Look great but can see a lot better with bar mounts. Did not put them on this one.
