Replace Battery and Memory
There has been some discussions about battery replacement. I mentioned that I am getting a new one for the next riding season.
With the newer bikes (Rushmore) and all of the Boom Box electronics - when I replace my battery (disconnect it), will I loose all of my memories for the Boom.? Or, is there some sort of a temp electronic memory (battery) What about the security system, will I loose that code also?
Thanks
Thanks
Security system is not affected in any way when you replace the bikes battery.
Same goes for replacing the FOB battery.
The PIN you set remains until you either change the PIN yourself, or the entire security system is replaced.
