2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Engine rattling sound ?
Old 12-25-2017, 02:28 AM
lopoko9724's Avatar
lopoko9724
lopoko9724 is offline
Default Engine rattling sound ?
Hello?
Mine is 2014 roadking classic (International version)
I've installed SE 110ci stage 3 kit on it when the miledge was about 11,000miles and it's about 28,000miles now.
I suffered from some rattling sound form primary a while ago, then it was fixed after replacing the compensator with baker's and primary inner bearing,clutch hub bearing with new ones.
But a few days ago, the motor started to make another more strange and bigger noise from the engine side.
Can anyone recognize what make this noise?
Lifter? rocker box?
It drives me crazy now.....
Old 12-25-2017, 07:02 AM
EasternSP's Avatar
EasternSP
EasternSP is offline
Received 21,933 Likes on 8,435 Posts
Sounds like lifters to me.
lopoko9724 (12-26-2017)
Old 12-25-2017, 08:31 AM
dave the welder's Avatar
dave the welder
dave the welder is offline
I'm going with lifter as well.
Old 12-25-2017, 09:38 AM
oakmossy's Avatar
oakmossy
oakmossy is offline
sounds like lifters, but could be anything including comp. I would not run your bike much until fixed.
If you have a long screwdriver ( one end on the engine areas, and then the handle against your ear) or mechanics stethoscope check out low end or rockers, ie different areas. That might help locate the issue. I am not a pro tech however so just my guess.
Old 12-25-2017, 11:01 AM
roadpop's Avatar
roadpop
roadpop is offline
Location: Living 33yrs in Sunny Florida !!! Living the retirement dream....Love it!!!
It sounds like the motor has a miss
Old 12-25-2017, 11:13 AM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is offline
Sponsor
Received 1,629 Likes on 1,177 Posts
I'd say lifters, or possibly a bent pushrod.
You can easily lift the pushrod tubes and see if any of them are loose.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 12-25-2017, 05:20 PM
lopoko9724's Avatar
lopoko9724
Thanks All,
My friendly mechanic also says it is lifters.....
The lifters and push rods are SE ones which came with Bore up kits.....
I think I should go with S&S ones...
Old 12-25-2017, 10:38 PM
lopoko9724's Avatar
lopoko9724
I've ordered S&S premium tappets 330-0175,
By the way, when I throttle the bike when start or very low rpm, I can feel the motor hesitate a little bit, it is very short time but it makes me hard to cotrol when the motor is in very low speed. (Can also be checked in the attached movie.)
Does this symtom have any relation with lifter issue???
And, is there any possibility that the motor have problem in cams(SE-585 also from the big bore kit)?
Bike runs well...excepting in very low engine speed and the rattling sound is main problem.
Old 12-26-2017, 07:16 AM
jpooch00's Avatar
jpooch00
jpooch00 is offline
Originally Posted by lopoko9724
Thanks All,
I put the S&S Premiums with the factory-installed shims in my '15 Limited and adjusted the push rods 1/4 turn "off the shim", along with a set of Rockout rocker shaft shims. Near-silent valve train now. Night and day difference in the appearance and performance between the POS H-D lifters (Mexican? Chinese? Who TF knows?) and the Made-in-USA, quality S&S parts! Also, no more start-up clatter.
IMO, this is the way to go. No further improvement possible in quietness or operation, AFAIK.
ROCKOUT Rocker Products (12-26-2017)
Old 12-26-2017, 05:19 PM
lopoko9724's Avatar
lopoko9724
Thank you!
I've ordered a set of rockout in amazon.
I will install these also when lifter replacement.
ROCKOUT Rocker Products (12-27-2017)
Quick Reply: Engine rattling sound ?
