Oil Archive (no new posts) An archive of oil related questions and comments.
1988 Harley Davidson Softail FXST
Old 05-12-2017, 12:30 AM
eek88dj's Avatar
eek88dj
eek88dj is offline
Default 1988 Harley Davidson Softail FXST
Where is the oil drain plug? I saw the hose from oil tank I drain it but where on engine do drain the oil ? Can't find oil plug..
Old 05-12-2017, 06:38 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Which oil drain plug, your bike has three oil reservoirs? If you are servicing your bike I recommend you get yourself a factory service manual, which will show you what you want and a whole lot more that you need to know. Your local dealer can supply - don't buy a cheap aftermarket one, get the real deal.
Old 05-12-2017, 07:33 AM
eek88dj's Avatar
eek88dj
eek88dj is offline
Default Drain Plug
Thank you, oil tank I drain from the hose to the frame. There's suppose to be oil drain plug, I think. I know where the primary and transmission plug is. I just trying to figure it out. I will buy a manual. Thanks
Old 05-12-2017, 07:37 AM
eek88dj's Avatar
eek88dj
eek88dj is offline
Default Oil drain
Think there only one resvior on the rt side?
Old 05-18-2017, 06:51 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,532 Likes on 4,631 Posts
The only way to drain engine oil is to drain the oil tank, there is no oil drain plug on the engine.
Gliden
11-10-2013 09:58 PM
vonzip
10-02-2009 06:13 PM
BigDeuceDoty
08-04-2009 03:54 PM
Beerninja
12-24-2008 08:15 PM
yzag
Exhaust System Topics
01-06-2008 07:11 PM
Quick Reply: 1988 Harley Davidson Softail FXST
