fork oil
5 wt is stock in harley forks.before you jump to high try 7.5 or 10 wt.as far as how much,replace what you take out.i think its around 8 ounces(each side) or so.don't forget to replace the flat rubber gasket under the fork caps.i just noticed that chart that yamaharley post is from maxima and i do believe is wrong.type E is for older non cartridge type forks ,type B is 5wt and is standard , type heavy wt (or screaming eagle heavy)is 10 wt.i may be wrong on this but according to my dealer thats the weight listing for harley brand fork oils.
