Ricor Intiminator vavle
Old Jul 4, 2014 | 05:14 AM
soberjoe's Avatar
soberjoe
Default Ricor Intiminator
Anyone have problems with oil leaks using 5wt and the RICOR INTIMINATOR?
Seems like the fork seals would leak even sooner with such light oil.
Anyone drop them on top of a Harley low profile lowing kit?
Old Jul 4, 2014 | 05:33 AM
bartk's Avatar
bartk
no issues at all. Installed these + - 5000 miles ago. Working perfect.
Old Jul 4, 2014 | 06:25 AM
soberjoe's Avatar
soberjoe
Are you on stock harley springs and dampers?
Old Jul 4, 2014 | 06:32 AM
Campy Roadie's Avatar
Campy Roadie
Joe
What would lead you to believe that 5w oil and Intiminators would cause fork seals to leak? I run RaceTech .090kg springs, Intiminators & 5w oil on my 39mm Super Glide forks. Fork seals leak for a variety of reasons; torn or otherwise compromised, just plain old and worn out or scratches in the fork tube in the swept area. All that said, I don't know it all, but what weight oil in the fork legs shouldn't have any effect on fork seal leakage.
Old Jul 4, 2014 | 07:33 AM
soberjoe's Avatar
soberjoe
Just old school thinking. Lighter oil finds the weak spot in the seal sooner.
Im glad to hear your good report. Taking the front end apart isnt much fun.
Old Jul 4, 2014 | 08:09 AM
bartk's Avatar
bartk
standard springs and dampers.
Old Jul 4, 2014 | 09:28 AM
soberjoe's Avatar
soberjoe
I'm thinking the intiminators should work just the same on standard or lowered. And I read in their FAQ's that there is about a half inch gain which would be great. I don't really need the lower kit but it's in there.
Old Jul 4, 2014 | 10:35 AM
qtrracer's Avatar
qtrracer
Old school thinking should have you thinking that the most likely scenario is seals getting damaged during re-assembly.
Old Jul 4, 2014 | 02:50 PM
grbrown's Avatar
grbrown
Cool
True. A common theme on HDF is someone asking why something doesn't work right, just after they rebuilt it!
Trex
Feb 17, 2017 06:10 PM
S.D.M.F
Oct 24, 2013 03:07 PM
Redhill Phil
Nov 20, 2012 04:14 AM
HDAce
VRSC Models
Mar 15, 2011 06:21 PM
moblmowr
EVO
Jun 22, 2008 12:49 PM
