Oil Archive (no new posts) An archive of oil related questions and comments.
Oil Mixing Question
Old 10-28-2017, 04:42 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
Did you check the level to see if you even need any more? My 08 calls for 38 on a drain and refill and 32oz fills is up to where the manual specifies.
Old 10-28-2017, 05:01 PM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is online now
Received 1,745 Likes on 929 Posts
Everything is going to blow up if you mix the oil, may even affect the space, time continuum...YD
Old 04-05-2018, 07:14 PM
Idahokid's Avatar
Idahokid
Idahokid is offline
I use my primary to get rid of my extra oils.Most of the time it’s all 20w50.I have mixed different brands and sometimes synthetic and semi synthetic oils.Lucas,valvaline and whatever else I used to change the engine oil with.Its all slippery.Ive never had an issue.
Old 04-06-2018, 05:32 PM
st john's Avatar
st john
st john is offline
I think Yankee Dog was trying to tell you that yes, use the Mobil to top it off. I have done it before because guess what I forgot to put the plug in so I completed the change with M1. Do I hope I have not changed the world axis, no not really.
Old 04-06-2018, 06:50 PM
GregGillette's Avatar
GregGillette
GregGillette is offline
Bought my bike new so likely was full of Harley oil. I do all 3 holes each year with Mobil1 vtwin. Since primary is 45oz dry and 38oz wet, it was mixed at that point with something different. Betting most bikes have had a mix of some sort
Old 04-15-2018, 08:15 AM
h7009's Avatar
h7009
h7009 is offline
Default Different oila
Actually, not true, if you look at the part numbers for bikes pre-2017, it/they all are the same part number.....It is ALL the same oil, my 2013 103 and my 2011 96, used the same part number in all three holes... Harley just trying to make it hard.... Mix what you want it will work.... CSM-H
Originally Posted by PDB17UltraRG
Depend on your Bike the new models 17s and. Newer use Motor oil in all 3 holes but the older models use three different oils, they primary oil for a reason why take a chance to save 7 bucks
Old 04-15-2018, 09:07 AM
PDB17UltraRG's Avatar
PDB17UltraRG
PDB17UltraRG is offline
Check this oil guy out.
https://www.bobistheoilguy.com/
bkgabby
2014-2023 Touring Models
31
10-19-2016 09:12 AM
Panchorelly
09-11-2012 05:09 PM
longhaul-2007
05-04-2012 09:34 PM
Fat-Bob-Brad
04-03-2011 12:39 PM
Tropical Andy
06-06-2010 08:29 PM
Quick Reply: Oil Mixing Question
