primary oil question
Old May 2, 2012 | 11:43 AM
longhaul-2007's Avatar
longhaul-2007
Default primary oil question
hey guys, I wanna change my oil and use 20/50 syn, but in the service manual for my 07 sporty it calls for a different oil in the primary. can I still use 20/50 in the primary? thank you for any help
Old May 2, 2012 | 11:54 AM
Scuba10jdl's Avatar
Scuba10jdl
As long as it is safe for wet-clutches.
Old May 2, 2012 | 11:57 AM
Ghost2277's Avatar
Ghost2277
I'm sure a lot of people will fill this thread with look at the oil section, or "do a search", or this has been hashed over millions of times. The question does get asked a lot but that's the whole point of forums to ask questions and become more knowledgeable about your bike. I am a semi newbie as well and have asked this same question before. What I found out is you can use 20/50 in the primary but a lot of riders don't. I use the HD formula +, it works fine for me. You can use Dino oil, you can get Spectro or Amsoil, there are several brands that make a "primary" oil and it all seems to amount to about the same kinda discussion as Ford VS Chevy. So anyways there's my input take it for what you will.
Old May 2, 2012 | 01:34 PM
Big Trev's Avatar
Big Trev
Originally Posted by longhaul-2007
can I use 20/50 in the primary?
Why would you want to do that?
Old May 2, 2012 | 01:54 PM
hairbone's Avatar
hairbone
They make an oil that is designed for the sportser gear and chaincase(primary). I would leave the 20/50 for the engine oil.
Old May 2, 2012 | 08:21 PM
fox4's Avatar
fox4
Go and get the Formula + primary and transmission fluid from your HD dealer. It is made for a Sportster.
Old May 2, 2012 | 08:39 PM
Jackie Paper's Avatar
Jackie Paper
Just use Harley's stuff. Safer that way. Probably cost twice what the Walmart stuff cost and 2/3 of what the fancy stuff that the people who get the Walmart stuff and add food coloring and pour it in their fancy bottles does but no more often then you need to change it. Its not that expensive. Do not change it any more often then manual says. Actually that is probably 3 times too good. Mine has 40K. Runs like new and I seldom change it but once ever year or so and the oil filter ever two years. It will break long before wears out and not due to oil. 48 years of experience talking here and have done all my own work since 1964.
It's probably OK to use Moble syn 15-50 oil but use Harley's transmission and primary fluids and Harley's oil filter and air filter. There is all kinds of stuff close but overall your are better off with Harley's primary and transmission fluids. They will probably work best and I have used and tried everything including all these recommended by the people on here. Do I look like the person who would steer you wrong???
Old May 2, 2012 | 09:35 PM
HarleyScuba's Avatar
HarleyScuba
I've tried others.
I've stopped trying and use Formula +.
The Syn 3 was amoung the worst in a tranny.
Old May 3, 2012 | 12:41 AM
Shredding rubber's Avatar
Shredding rubber
Any JASO stamped oil will work. I use rotella 15w-40 conventional in my primary and in both my jap bikes. It resists shear very well,which is important because in jap bikes and sporsters the oil also lubricates the tranny. The gears meshing beats the crap out of the oil,turning it into water fairly quickly.
I change the oil in the honda's every 3000kms simply because the gears meshing kills the oil.
Now I'm sure the formula+ will work great however so does rotella at less than half the cost.
Whichever you decide to use just change it at regular intervals and you will get a long service life out of the clutch and tranny. Jmo
Old May 3, 2012 | 03:01 AM
ahhwataday's Avatar
ahhwataday
lol
Ive read a lot about using mobil 1 gear oil
