Oil Archive (no new posts) An archive of oil related questions and comments.
Castrol Edge 10w 40?
Old 08-30-2018, 04:26 PM
Redoilokie's Avatar
Redoilokie
Redoilokie is offline
Received 14,731 Likes on 5,861 Posts
Originally Posted by Mastiff107
Until now I had not thought much about it, but yes, I do feel the need to argue every microscopic detail.
I don't have a problem with that, and I suspect it was purely for my benefit. Before you go away though, here is what we've been trying to tell the OP.
Now, by all means, feel free to go argue every little detail with him.
Old 08-30-2018, 04:59 PM
Cozz's Avatar
Cozz
Cozz is online now
Received 4,875 Likes on 1,860 Posts
Use the correct weight oil. Synthetic will make more top end noise than conventional oil. Pick your poison.
Use the 10w40 in your car.
Old 08-30-2018, 05:00 PM
Jonny Rotten's Avatar
Jonny Rotten
Jonny Rotten is offline
Originally Posted by Redoilokie
You have your answer here, but if you're the sort who has to argue every microscopic detail, just say so now. That way I can ignore you and won't be drawn back to a single one of your threads.
Thats fine, stay off my threads.
My question was never answered
It was a question regarding a spec sheet, specifically oil being tested at 100c that I read about. I'm not an oil expert so I asked for advice. If thats to much for you to handle then back off and let someone with that knowledge answer .
I also asked for any oil tech savoy people that may be able to help which obviously isn't you with your cut and paste graph
Old 08-30-2018, 05:24 PM
n5tf's Avatar
n5tf
n5tf is offline
Some are trying to be helpful here. Best advice I saw was use the oil that you got in a good deal in your car. I did find that on my old Harley Road King that Mobile 1 did tend to allow a little more noticeable valve rattle at stops.
Old 08-30-2018, 05:29 PM
shanneba's Avatar
shanneba
shanneba is offline
The ASTM D445 test determines the SAE J300 oil viscosity at 100C (212 F) to determine the viscosity grade of the oil. No other testing at that temp is done.
HD recommends a 20w-50 grade oil for your engine. a 40 grade oil is thinner than recommended.
(Harley stopped selling their HD 360 10w-40 oil, but used to recommend it only when used in temperatures under 40 F.)
Old 08-30-2018, 05:37 PM
Redoilokie's Avatar
Redoilokie
Not an oil debate, I picked up 12 quarts for $2 each, Dirt cheap. Normally around $10. Its got nothing but great reviews but will it work in my RK?
My bad. I assumed the bolded text above was the primary concern. How the hell did I ever make a mistake like that?
Old 08-30-2018, 05:56 PM
Jonny Rotten
By reading half of the original post and commenting on it....glad we got that figured out
Old 09-03-2018, 06:26 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,523 Likes on 4,628 Posts
You bought the wrong viscosity oil.
You got a great deal on 10w40 because not many modern engines use that grade.
Old 09-03-2018, 06:41 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is online now
Received 6,420 Likes on 3,311 Posts
15 or 20w50 or 60...straight 50 or 60 weight depending on where you live...10w40 is ok for metric bikes, friend of mine ran it in his GL1800 for 300000 miles...never an issue but it’s a car engine in a Goldwing really and share fluids with clutch.
stick with recommended weights, tolerances in a Harley are not as tight.
Old 09-03-2018, 06:44 AM
Redoilokie's Avatar
Redoilokie
Guys...That's not what he asked...
Quick Reply: Castrol Edge 10w 40?
