Oil behind derby cover ??
Howdy,
I was just wondering about the oil that is behind the derby cover (clutch inspection cover). Is this oil from the transmission, which I am assuming or is it from the crankcase? My bike is a 07' Road King.
Also my HD service manual recommends the HD tranny oil for the transmission, does it need to be the HD brand or are there substitutes?
Mike[/align]
Mike[/align]
Hey thanks guy's,
I lost a few ounces of oil when I changed the derby cover to a different style. I was just looking in my HD service manual and it only lists quantities for after draining the primary. Is there any type of line in there for a full mark or how do you gauge what quantity to add to top it off?
Thanks again,
Mike
Thanks again,
Mike
Thanks a million Bill,
I figured that there must be a way of topping it off without draining and re-filling. I have read my owners manual and the HD service manual and so far the only things listed were quantities to re-fill after draining. I just wanted to top it off.
Thanks again,
Mike
Thanks again,
Mike
ORIGINAL: hd.road.king
Thanks again,
Mike
Thanks again,
Mike
Take Care,
Bill G
Your tramsmission oil is in the tranny itself, the motor oil is in an oil tank a part of you tranny under you transmission, if you look under the tranny you will see a flat bottom side of oil pan for you motor, the drain plug is there also. Behind your inspection plate is the primary oil, your bike should be level when you fill this the drain plug is on the bottom side of you primary, and you fill is through the derby cover hole.
ORIGINAL: Bill G
On your 07 Road King, the level should be just below the edge of the opening without runing out or spilling over with the derby cover off leaning on the jiffy stand on level ground.
Take Care,
Bill G
Take Care,
Bill G
The pic below will show you what we're talking about here. It's the silver outer circumference around the VPC clutch in the middle. You'll see it when you look in through the derby cover. The oil should just be up to the edge of that with the bike upright and level.
[IMG]local://upfiles/8308/AE1AE87FF8CA48D097E1750F4DB412B1.jpg[/IMG]
ORIGINAL: glide
That would be a bit too much oil. The oil level in the primary is measured in ounces specific to the model and in most cases will come up to the silver edge of the clutch basket only. Overfilling it will cause problems with shifting and finding neutral.
ORIGINAL: Bill G
Take Care,
Bill G
Take Care,
Bill G
Onthe earlier models the primary takes 32 ozs or 1 Qrt. The 07 takes 38 ozs as they are a little diffrent.
Have a nice day...
Bill G
