Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
darkhorse compensator
  #31
Old 11-26-2014, 09:07 AM
HD Bobber's Avatar
HD Bobber
HD Bobber is offline
HOG, the new bikes have a totally different crank shaft that has much more spline than the older models and the offset is different to line up the chain to the basket. For people that don't have access to machinery it would be pretty damn hard to fit.
  #32
Old 11-26-2014, 09:09 AM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Originally Posted by Hogpro
I have the comp out of my 2002 softail minus the spring. Wonder if I can retrofit that into my 13 bagger? A little help here. I want a comp I won't have to replace in another 20k miles. That is less than a year of riding to me.
Who knows if I can make this work with the older comp?
No. The shaft on your 02 is different. I am running a gen 2 comp and added an extra spring. So far so good. You can add an extra spring washer to your 2014. I do 20k a year as well. Sux this is a maintenance item for us.
  #33
Old 11-26-2014, 09:16 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,575 Likes on 3,822 Posts
The older bikes have a 10 tooth spline on the crank. Newer versions have the much stronger serration. (it looks a smaller but it is much stronger and easier to machine accurately) Just a few .001s make a big difference when you tug in opposite directions pulling out decelerating on the rotating masses. It's pretty easy to strip out the spline on the alternator rotor on the 10 spline ones..When this happens, most think the comp nut came loose.
  #34
Old 11-26-2014, 09:32 AM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
Thanks for the info guys. My bike is a 13 not a 14 but it seems that isn't going to work. Well I have now joined the ranks of those waiting for a better aftermarket alternative. I hate to spend $400 on part that is going to wear out again so soon. It seems a new spring pack with a new compensator makes sense, correct?
  #35
Old 11-26-2014, 09:37 AM
soft 02's Avatar
soft 02
soft 02 is offline
If you can find a gen3 comp that doesn't include the rotor it should be about $200.
  #36
Old 11-26-2014, 11:49 AM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
Louie,what is that part number? Also do you think a new spring pack is necessary?
Drew
  #37
Old 11-26-2014, 12:18 PM
soft 02's Avatar
soft 02
soft 02 is offline
Drew
I'll have to look it up when I get to a computer. Depends on the spring pack and if its weak. Not sure if you can just buy the sprocket and ramp pieces. Last one I bought was $219 and didn't come with a rotor. I have extra rotors at this point.
  #38
Old 11-26-2014, 04:39 PM
soft 02's Avatar
soft 02
soft 02 is offline
Drew
http://www.latus-harley-davidson.com...ASSY-TRANS.htm
  #39
Old 11-28-2014, 01:59 AM
cmashark's Avatar
cmashark
cmashark is offline
Damn. Wish this was available now. Monday afternoon I am starting the assembly of my 113 and will be installing the Baker Attitude adjuster at the same time.
Chris
  #40
Old 11-30-2014, 07:19 AM
union53's Avatar
union53
union53 is offline
I've been trying to keep up with this. I'm new to Harley engine mechanics and their short comings. I will be getting my first Harley early next year and I'll be doing my typical tear down and rebuild process.
When would something like the up and coming baker compensator be installed? New from the show room, after I get some miles on the bike, or when the stock one wears out?
Quick Reply: darkhorse compensator
