1997 Wide Glide Transmission Problem
I recently purchased a 1997 Wide Glide from a private seller. The bike is beautiful and was maintained well. The seller had extended forward controls on the bike, and it was uncomfortable for me to ride. I went to my local dealer and had them order a standard length shift linkage and brake pushrod. I installed the shifter no problem, but the brake rod was too long. Found out aftermarket pedal and ordered a new Harley one. It also didn't work so I had to cut and weld pushrod.
I test rode all day Saturday 4/23 with no issues. On Sunday 4/24, I took it for a ride to my parents house and it rode great. On my way back home about 15 miles into my 65 mile ride, I heard a clunk sound and the bike started to shake and sound odd as it started to rev up. I held the clutch and shut it down as I pulled onto the shoulder. After looking for oil or anything obvious, I found neutral and tried to start. It sounded like the starter was turning but not actually turning the motor. Same way with the bike in gear with the clutch in. If you try to start in gear without the clutch, the bike tries to move forward.
I'm really hoping it's something small like a key way or something. I can't afford to put a new tranny in a bike that I've only been on three times.
Yes the motor turns when in gear with no clutch. As soon as you either put it in neutral or squeeze the clutch, the starter sounds like it's not meshing with anything. I haven't really looked at it since getting it home. It made a clunk sound that sounded like it was from the primary case. I noticed that 4th and 5th gear were hard to find needing hard upshifts to get into after moving the controls back to stock location.
Sorry I haven't been able to respond.
My father in law and I opened up the primary and found it was a dry enclosed belt drive. A bolt vibrated out and hit the belt shredding it and in the process, the bolt got stuck between the case and clutch basket and ground down the teeth on the basket. It was a bolt that wasn't even needed anymore with the belt drive.
Thanks for the responses!
