Fluid Leak between Transmission and Primary Case
If I am wrong, then fine. However, the transmission would be way overfilled screwing it in till the o-ring touches on most sticks since it about an inch up to that o-ring.
My 2009 manual says "With motorcycle on a level surface and resting on jiffy stand, check lubricant level. a. Insert filler plug/dipstick into transmission fill hole but do not thread in." Softails say the same.
Are you referring to the rubber tube in your statement? "The transmission vent was replaced about 400 miles ago" If so, it could still be stopped up. Why did they replace the tube?
Thanks for clearing that up - I might be in the same boat. When I pulled my derby cover off a few days ago my primary was overfilled to the point oil ran out all over the floor; a very unpleasant surprise. I drained and filled it properly and will check it again after a couple hundred miles.
Yes bike was upright on a lift. Had just changed the engine oil so that's unknown. After I saw these threads I checked my tranny oil and that's full. No visible leaks anywhere.
Like I said, right now all 3 are properly serviced - I'll ride a couple hundred miles then check all 3 again.
By looking at an exploded view of the setup , I'm sure that a leak in any of the seals would show up as an external leak .
If the mainshaft / clutch pushrod is the culprit , why is it leaking and how do I fix it ?
That is what I think and said in post 19 but may be confusion in what I said about seal for pushrod.
Why it leaked is I think you overfilled transmission (maybe) and it just is running in past the metal umbrella on the clutch rod oil slinger.
Listen and watch here around 4 min
Listen to what he says around 5 minute
