Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
hydraulics clutches
Old 09-19-2017, 12:32 PM
dkrupka's Avatar
dkrupka
dkrupka is offline
Stage I
Default hydraulics clutches
2016 street glide. The brake fluid in my clutch master cylinder is gray and has a metallic tint to it (like metallic paint).
I stopped at the Appleton Harley shop and the service writer told me the fluid is not a covered part under warranty. I know this. He also told me the system is not a closed system which I know it is, just like the brake system. I am an ASE Master auto tech for 17 years. Any thoughts
Old 09-19-2017, 09:59 PM
J F GO's Avatar
J F GO
J F GO is offline
Received 3,346 Likes on 1,746 Posts
Yeah, if you already know all this why did you go there. You can flush it yourself of about 30 bucks, which would be both the front and rear breaks as well.They recommend you do that every two years. What am I missing ? Not trying to ridicule you, just wondering what your concern is.
Old 09-20-2017, 06:09 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
H-D hydraulic systems are not 'closed' systems, they are subject to ingress of air and hence water vapour. It is the latter which degrades hydraulic fluid and the main reason why it should be changed at intervals. Just bleed your systems, if the appearance of the fluid bugs you. How often do you check the systems of customer vehicles?!
iatemenchi
06-21-2016 03:41 PM
chromepony
General Topics/Tech Tips
02-16-2015 09:16 AM
Ace07FXDL
04-11-2010 08:44 PM
Biker Vet
07-27-2008 06:49 PM
JSW
13
08-14-2006 10:02 PM
Quick Reply: hydraulics clutches
