Throw out bearing gone
http://www.kandgcycles.com/clutch-th...hoChDEQAvD_BwE
these used the release finger in the kicker cover (or electric start kicker style cover) to engage the push rod. The new wafer bearing did not workwell with the finger setup.
You can however use our larger heavy duty bearing with the finger actuator, you just have to change the push rods over to a 87' 5 speed style setup. We have different length center and throw out rods. just tell me the overall length and I'll figure out a combo that works for you.
They used wafers with fingers but they just didn't hold up as well as the old cone bearings.
here's my emergency fix the last time the throwout bearing went south. it was washer on washer because the rollers were gone. i couldn't take all the slack out of the cable so i had to come up with something to get the clutch to release so i could get the bike in gear. i had about a 50 mile ride to get home through several small towns. shifted without the clutch and rolled through every stop sign and stop light. the screw clamp held the **** on the end of the cable out farther on the clutch arm and the wire tied the clamp into place so it wouldn't slip. it worked and i got home.
corliss@bakerdrivetrain.com (01-22-2018)
