Clutch drag
Hoping the experts can clue me in here. 2012 FLHTK Twin Cam, mechanical-cable actuated wet clutch. Barnett carbon fiber plates and Dexron VI fluid (recommended by Barnett). It's wearing out apparently, and I have a complete new set of steel and carbon fiber plates (Barnett) ready to go, but I would like to understand what is happening and why. I've worn out a few dirt bike clutches and they always start to slip, not drag, when they are ready for replacement. In this case, with the Harley, it's set up properly according to the service manual with actuator rod clearance and lever free play. When new the service manual setup procedure always has worked but with miles and time, when set up properly according to the manual the clutch still has very significant drag (way too much) until it gets hot, then it's better but still not right... still drags. No slippage.
I am wondering if the entire pack is worn to under limits, too thin, if this would cause drag? Just shooting from the hip I would have thought the opposite, that a too thin pack would tend to slip. I have a complete new set of plates, fiber and steel, and do have the ability to measure the thickness, but just would like to know what's going on for my own knowledge bank. Thanks in advance! |
Worn plates are going to cause a slipping issue not a dragging issue. Couple things to check, if you have a dial indicator put it on the clutch release plate, pull the lever in and see how much the indicator moves. This will tell you how much release you are getting. You want at least .070" plate separation. If you are not getting that much release you may have a bad or sticky cable or possibly a grooved clutch basket that is not allowing the plates to separate.
Originally Posted by Mark@ Baker Drivetrain
(Post 17417582)
© 2024 MH Sub I, LLC dba Internet Brands
