Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Can’t stop the grinding please help
Old 06-14-2018, 04:30 AM
Church209's Avatar
Church209
Church209 is offline
1st Gear
Default Can’t stop the grinding please help
I have a 1996 Harley Davidson Rd., King and when I try to started it the jack shaft assembly just grinds on the ring gear and I noticed that my clutch basket And clutch hub wobble on the shaft what causes this and how can I repair it
Old 06-14-2018, 04:43 AM
Kingglide549's Avatar
Kingglide549
Kingglide549 is offline
I assume you tried this with the primary off?
2, if you grab the clutch basket can you wiggle it ?
Old 06-14-2018, 05:46 AM
Church209's Avatar
Church209
1st Gear
It's already chewed up when rain gear it's chewing up the second one
Old 06-14-2018, 05:50 AM
Kingglide549
The ring gear is attached to the clutch basket/ drum and held on the shaft with a LH nut.it will be solidly mounted with no flexibility
Are you sayng it moves in out? wobbles?
Old 06-14-2018, 05:57 AM
Church209's Avatar
Church209
1st Gear
Yes what I'm saying is when I try to start the bike the Jack shaft assembly engages in the clutch ring gear and it starts wobbling and starts grinding and choose at the teeth I put a new ring gear on it I've put the another clutch pack on it I put a new ring gear on it put a new starter put new bushings in in my bell housing covers put a new jackshaft assembly and yet it still does the same thing
Old 06-14-2018, 05:59 AM
Kingglide549
Pull the basket off and check it .
perhaps the transmission splines are wiped out , nut lose, etc.
Old 06-14-2018, 06:00 AM
Church209's Avatar
Church209
1st Gear
Yes I've done that the splines are fine the nut has been retorqued down check the adjustment on my primary chain I put a new drive belt on it
Old 06-14-2018, 06:06 AM
Kingglide549
If the basket is loose its loose, if not, the transmission shaft is. It cant be both ways.
In either case, you should be able to grab it and move it by hand.
I don't mean rotate it.
I mean- In and out, or cockeyed.
Old 06-14-2018, 06:12 AM
Church209's Avatar
Church209
1st Gear
Yeah I tried that and I cannot move it by hand it only starts wobbling when the jackshaft assembly and gauges the ring gear and tries to turn the bike over then it just grinds
Old 06-14-2018, 08:55 AM
Kingglide549
Is your inner primary loose and broke?
transmission bolted dwn?
can you post a video?
Quick Reply: Can’t stop the grinding please help
