Vibration 1600-2100
Received 5,388 Likes
Your problem could be as simple as the tune not jiving with the components you replaced. I had a similar issue with extreme vibrations on deceleration. It was so bad it broke both my inner fairing brackets. Even though it ran great, the tune was the culprit. There wasn't a simple solution to fix it though. Just kept making minor adjustments in the affected RPM ranges until it went away. Did this using a power vision. You might be better off just getting it dyno'd given that you don't find any mechanical problems. Good luck.
But I have this vibration in full stock and now with stage 1
